Hard starting..at least 10 mins of cranking!
Old Man
I have a 1986 Johnson 150 VRO,it has been a hard starter since i got her 3 years ago but this season she will not kick over for at least 10 min of cranking, when i tilt the engine up fuel leaks out of the carbs (about a soda caps worth) I changed all the fuel lines inside the engine compartment and the primer bulb will stay hard during this cranking time.after it gets started i would run it for an hour,anchor and fish for an hour and the same thing happens even tho i didnt tilt the motor!our season is short here and id like the least time consuming repair possible,any clues to what i can do?
Solittle
Re: Hard starting..at least 10 mins of cranking!
Check fuel pump pressure and I bet you have some crud in one or more of the carbs.
Old Man
so basicly i should pull the boat out and bring it home,remove carbs,clean internal parts,replace fuel pump to be sure.Is that a good start?
Walker
SoLittle is right on. Or you could wait til you burn up your starter and then fix everything.
jy118lfd
This motor has a primer choke system. You can try to turn the little red lever on the starboard side towards the rear and pump the bulb then turn the lever back and crank her up if it starts then you have a primer choke issue. Get a factory manual and it will explain it better. I feel if it runs ok after it is warm then you have a cold enrichment problem and the primer system is like a choke on older motors
Old Man
Helpful post <br />I did a search in past posts and found a helpful one,Checkout Dhadley's reply concerning a starting procedure.<br />Well, i did it and i got it started in 3 tries!!gonna try it every day at least twice a day for a week and see if its consistant.<br />If it works i still will rebuild carbs.<br />Thanks all,I will post a reply with results.
Silvertip
Remember that the "hold the key in for a 7 or 8 count" procedure only works if the primer bulb is firm. The primer solenoid is a valve, not a pump so some system pressure is required for this to work. The primer solenoid can be checked by disconnecting one of the primer hoses at the carb, then turning the key ON (not start) and pushing it in to see if fuel is expelled. If so, its working. If not its either plugged or in need of replacement.
boobie
The key has to be pushed in when the mtr is CRANKING. This lets fuel from the vro through the primer to the mtr. Read the instructions in the owners manual.
