hard starting ended up with not peeing
boat 1
Hello,<br /><br />I have 2002 Merc, 9.9 hp 2 strk. S/N 0T531840. I try to start and trying to test the choke.now the engine starts for a few seconds and quit, and no water coming out.<br />If bad water pump can cause hard starting?<br />what should i chk next?, Should I change water pump and try it agian?. How do i lower a LU after remove 3 bolts?. Can i get parts from iboats?<br /><br /> Any help will be appreciated.
boat 1
Re: hard starting ended up with not peeing
Hello. <br />can not order service manual 4 9.9 hp 2002 2strk from iboats. It seems to be new. any help will be appreciated to lower a lower unit. <br /> <br /> Thank you
