Hard starting, even with choke. 1989 85hp force
frankygandolfo
Im having a hard time on its first start, when i put my hand over the carb while cranking, gas flows pretty good and starts right up, what could it be?
Nordin
Does you choke butterflies work and does they close properly?
Nordin
Yes, they should close almost completly.
Workshop manual says you should adjust the butterflies with a piece of writing paper between the carb throat and the butterfiles when closed.
frankygandolfo
ahhhh thats the problem then, thanks for the info, simple fix.
