Hard Starting
metriccrescentwrench
1973 Merc 7.5 which I'm repairing. It has good compression, good spark, and once I get it started it idles perfectly and runs good up to full throttle in gear. The only problem is that it takes FOREVER to start when cold, somewhere around 20 or so pulls. Any thoughts on what can cause this?
coastalrichard
Re: Hard Starting
Well...we all know that Merc's like, no make that love gas....is it getting enough priming?:rolleyes:
Re: Hard Starting
I pump it 'till the bulb is solid and choke it, don't know what else I can do beyond that. I used to have another old 7.5 which always started with just a couple of pulls, I really think this one ought to be able to do the same.
Chinewalker
Re: Hard Starting
Does this one have the pull choke with the cable? Make sure it's adjusted so that the cable pulls the choke all the way closed...
Sunfish12
Re: Hard Starting
You said it takes forever to start cold. does it start right up when warm?
Sunfish12
Re: Hard Starting
Try opening the choke just a hair to see if it starts.
Re: Hard Starting
I've tried it with the choke all the way closed, cracked open, half open, etc. etc. When it's cold it just flat refuses to jump to life within a couple of pulls like I think it should. After it's been running I can shut it off and it restarts instantly.
I'm tempted to get a carb/fuel pump kit and replace all the gaskets and diaphragms, but since it runs so good once it finally does start that I'm not sure if that's the problem.
