Havasu Boater
- Joined
- Apr 23, 2003
- 2
I have a 60hp Evinrude motor. After the a couple of hours or when sitting a long time the engine is hard to start unless I use quick start. There is fuel, but in checking the spark at the plug, removing the sparkplug wire you can see very little spark output on all 3 cylinders. What should the the firing spark distance be?. If you have any suggestions what the spark distance should be or what might cause the hard starting problem I would appreciate some help..
