Hi all,
Brand new member to the forum (and to boating in general), so I apologize if some of these questions might seem a bit basic.
So here's the background. Bought a 1986 Bayliner Capri 1800 bowrider about 2 months ago with a 1979 Mercury V-150 2-stroke outboard motor. Great boat, loving it so far. The previous owner told me "it doesn't like to go slow", which I've started to notice is VERY true. It wasn't much of an issue until I bought a 3 person tube and went out tubing the other day. With just 2 adults on the tube, sometimes I would be at WOT and it just wouldn't go fast enough to plane, it would just struggle along at slow speed. Once it gets to plane though, no problem, full speed ahead!
I decided on the fly to do a rough WOT test (3 adults and 2 toddlers on the boat, plus I didn't trim up as much as I probably could have), and at WOT, I was going about 50mph at only about 3500 RPM. The book shows WOT should be 5000-5500 for this engine. I did some reading on props and from what I understand, I could probably go down 2-4 inches in pitch.
The prop on the motor is a modular 3 blade 14.5x19 (I think the brand is Piranha since it's the only brand I've seen that make these props, but I can't find any identification anywhere, so I'm not sure). The original engine that would have come on this boat (125hp) calls for a 13x17 prop, so I assume the larger diameter for this engine is normal, but it seems to me that the pitch is geared towards top speed, which isn't really what I'm aiming for, especially if I'm going to have fun towing people around.
While researching props, I found this forum that talked about how the height of the outboard could also affect acceleration/speed. I did a quick test with the information I found online, and I think my outboard is about 2 inches below the "normal" height (cavitation plate about 2 inches below the keel of the boat). What's more, looking at the mounting points, the motor is mounted on the 2nd highest hole (out of 5), with each hole 3/4 of an inch apart, I assume I could go down 2 holes (1.5 inch) to the 4th hole.
So I suppose it's time I actually ask a question (OK, many questions). Here goes:
1. What pitch should I try instead (I'm thinking around 15), and should I change the diameter? (I plan on getting a second set of blades for my prop either way, so I might as well get something different from what I have now).
2. Should I bother raising the motor? I would like to think it would be a good idea, but it seems like a lot of work (the 2 bottom mounting bolts are deep inside where the onboard fuel tank sits). I'm sure that just changing the prop will help, but if there's a chance that raising the motor will have a significant impact, then maybe it's worth the effort?
3. Does anyone know if there's another company that makes these "modular" props other than piranha? I would hate to order new blades and find out they don't fit the hub.
Thanks in advance! (and sorry for the novel)
