ward cleaver
Thread starter- Joined
- Dec 15, 2007
- 174
1965 Evinrude 18HP that I just bought wasn't getting spark. So I pulled the fly wheel, filed the points shiney, checked the coils (oK) and reassembled. Now it gets spark so that problem is fixed. It was probably the rusty boot connection at the plug end. The problem I am working on now is that the throttle plate is pretty hard to rotate, sticking in spots. Definitely something wrong there. I disconnected the throttle plate arm at the silver clip and found that the throttle on the tiller moves fine. Its the throttle plate assembly that's the problem. I've had this same problem before on other outboards. This time it's bad enough that I need to fix it.
Do I need to lube somewhere under the fly wheel? Is the fly wheel nut on too tight? (40 ft/lbs)? It's not the carb linkage because it is hard to move even when the linkage isn't engaged. Where's the hang up?
