makassiouk
Thread starter- Joined
- Aug 2, 2010
- 12
Hi again.
What happens is that the motor would take a bit too many pulls to start and when it does finally catch it, it would behave as flooded for a while (blue smoke, etc). So I guess the fuel gets there but not the spark. The plugs are from this spring, I don't really know if they can go bad this soon. I suspect that it does not get the spark to begin with, and then it appears after a few pulls - this is consistent with what i see if i take the plug out and check by pulling the starter - at first I see no spark and then it comes eventually. The carb is cleaned by a mechanic early this summer.
What I do now is that first I just begin to pull the starter, and then only after several pulls I prime the carb and engage the choke - otherwise it gets really flooded and it's a complete nightmare to start then.
I don't know if it's indicative of anything, but the oil pressure lamp does not begin to flash at once when I start trying, but only after several pulls on the starter (oil level is good).
Are these some electrical problems?
