Hardwood floor refinishing
gonefishie
I'm pondering whether I should just replace the carpet cuz it is shot or I should refinish the floor underneath. It has been cover with carpet for who knows how long. Will take pic this afternoon after I pull the carpet off.
xxxflhrci
Re: Hardwood floor refinishing
Refinish the wood. IMO, it should be a crime to put carpet over hardwood.
gonefishie
I forgot to take picture but it's in bad shape. The low traffic areas look good but high traffic areas are terrible with lot of stains. The area by the front wall in the living room has what looks like glue or part of the pad stuck to it. It's about 1.5ft wide and runs the entire length of the LR. The genius that built the house put brick pattern linoleum on the unfinished hardwood floor in the hallway. This would be an "extreme" refinish job, sanding it down to bare wood, stain and clear coat, all of which I have no experience doing. The thing that totally blew me away was the huge amount of fine sand like junks below the padding. It was absolutely disgusting to think that I used to roll around on the carpet.
xxxflhrci
A pro can refinish those floors with minimal mess and intrusion into your life.
blairjbyrd
I have been refinishing hardwood for over 10yrs. Take some pics and I can guide you on what direction you should go.
Bob_VT
You have not lived until you have had the joy of floor snding and edge sanding....... I would refinish it
blairjbyrd
Bob you are exactly right. It is fun stuff:cool:
Bob_VT
There is actually an incredible amount of satisfaction that comes with re-finishing.
Here are two additional posts regarding re-finishing floors
Here is one http://forums.iboats.com/showthread.php?t=286558&highlight=floor
and the last floor I did was pine in my 150 year old plus house in my guestroom http://forums.iboats.com/showthread.php?t=185820&highlight=floor
The first hardwood floors I did in my home were actually black and that black turned out to be old finishes!
If you re-finish the flooring you can then use area rugs if you need them
rbh
Love hard wood floors, just through rugs under the couch and chairs to keep your feet warmer in the winter.
HopeSheFloats
I'm with the refinish the hardwood...did ours two years ago after 24 yrs of carpeting...never going back....rented all the equip from home cheapo...easy peasy...Plus it's great entertainment, watching the dogs and cat slip & slide as they try to tear thru the house :D
Plainsman
So true!!!! I have a puppy and he slams into the wall all day long.
I put down a ash floor around Christmas. Getting a sander in a few weeks when it's warm enough to open the windows for the stain. This is my first floor too.
I say go for it!!
PiratePast40
It's one of those tasks that are relatively easy - you just have to follow directions. A three pad vibrating sander makes it much safer for first timers and renting an edge sander will save you quite a bit of frustration.
To cut down on the dust, I place the vacuum cleaner outside and run a long piece of hose to it. Sounds a bit like an elk call when running but really keeps the inside of the house cleaner. That way you can do most of the painting first and not worry about ruining your new floor.
Like the others have said, it's a beautiful and rewarding transformation.
Skiuseme
The amount of Time and effort was not worth it to me to refinnish my floors. So I hired someone else to do it!!! 4 days for 957 sq ft.
Yes it was a mess and yes it was a pain since it was my enitre living level of my house(minus bath and kitchen).
$1800 was well worth his time and effort.
marlboro180
Wow, around 1.80 a square foot? Thats a deal. My guy, who has been doing my floors ( as well as my friends, customers, etc.) for nearly 15 years , now get 3.25 a foot . Still worth it though. He can make darn near anything look great.
Well worth writing the check IMO.
