Sierra Oil Pan Drain Kit
http://www.westmarine.com/webapp/wc...toreNum=10106&subdeptNum=10434&classNum=10440
My boat came with one installed, a cable attached from the plug in the to the boat drain plug to aid in pulling it out the drain hole. If you run the engine and warm up the oil they work great, if the oil is cold it takes a while to drain. It is much better than anything else I have seen.
a cable attached from the plug in the to the boat drain plug to aid in pulling it out the drain.....
any chance you can get a picture of how they did that?
I don't want to hijack, but do you have to add extra oil becuase it fills up the hose?
Ok I won't worry about it, if time allows I may still do it for others.No need to on my account I understand exactly what your explaining thanks for the information!
Hi Guys:
So sorry to disagree with the senior membership, but I had one on my 165 and took it off as it took such a long time to drain and I didn't like it cluttering up the bilge. I use one of those vacuum pump type oil changers via the dipstick tube. Warm the engine, 20 pumps, go have coffee, come back and the job's done.
kilowatts
