Re: Has anyone used a compression tester from harbor frieght
I have an Actron tester, with 5 differant plug thread sizes, its made in China, and was only $25, and comes with extra orings. The gage can read 5 to 10 lbs differant from others at times, but its generaly a leak somewhere that cause the differance. The main thing is that your cyc are with in 10% of each other, when taking readings. Put a little oil on the orings and you will get a good seal. I see nothing wrong with the cheaper ones, as long as your useing it correctly.
