Don S
- Joined
- Aug 31, 2004
- 62,321
Re: Has this ever happend to you (starting questions)
Well, there is most of your problem, You have a BY model. If you go up to the Adults Only sticky and go to the Volvo info section, you can download the OEM manuals for your engine and drive. They are SOOOOOOO much better.
Then you can use your Seloc as an expensive knee pad as it was designed.
One note, the nice clear wiring diagram came from the EF model, but I knew they were all the same in that time frame. I checked.
I re-read the diagram (SELOC 10-84)
