Hate vandals
triumphrick
Re: Hate vandals
Speaker Drivers
120
Multi-Channel Recordable Voice and Siren Driver Module
Four Channels Configurable as: Two Siren and Two Recordable Voice OR Four Recordable Voice
Maximum record time is 8 minutes divided between the number of voice channels.
Siren Sounds: Classic Yelp Siren, Temporal Coded Horn, and Steady Industrial Horn
Temporal Coded Horn meets ANSI standard for Audible Emergency Evacuation Signaling
Recordings stored in non-volatile memory
Voice channels accept momentary triggers
"One Shot" or Continuous voice playback settings
Option to trigger +V1 and or +S3 channels from a steady or pulsing input (ComboTrigger�)
Built-in condenser microphone for recording
Adjustable speaker volume and current draw
Powerful 24 watt audio amplifier for Speakers
Line Level Output Jack for Paging Systems and Amplifiers
PC sound card interface connector
Lifetime Limited Warranty
Operating Voltage: 11 to 14 Volts DC
Current Draw: .2 to 2 Amps, (depends on volume setting & speaker load)
Sound Level: 120 db @ 1 meter, 14 vdc, with one 8 ohm speaker
Max. Speaker Loading: 4 Ohms
Pulsing Input: 1/2 to 2 Second Pulse, 50% duty cycle
Size: 3" x 5" x 1.25" (76 x 127 x 32mm)
I owned my own security company and these were one of our favorite siren drivers. They are available for around $20. It and a speaker and 12v you can have a lot of fun....some motion lights will provide an output to trigger the device.
