haunted PTT
Home Cookin'
Happy Halloween. My sister has a 150 Yam 4 stroke c. 2005. While riding along, the motor started raising itself. Did it a couple of times. Seems to ahve resolved itself, but who knows. Anyone else seen this?
I'm assuming a switch got stuck, possibly inadvertently hit on the throttle (her 16 yo daughter was running it at the time). Suggested spray with CRC or something into the switches.
Re: haunted PTT
Is the PTT switch a thumb toggle switch? If so, it likely has some water in it. The water will settle to the bottom of the switch an make contact between the up contacts. Blow the water out and spray some oil in there.
Frank Acampora
Re: haunted PTT
It is also possible that vibration is causing a defective up relay to close. If cleaning the switch doesn't help and the problem returns, try changing the relay.
kahuna123
Re: haunted PTT
Frank step away from the bong pipe. You think a relay fails and makes a solid 10 amp connection???
Frank Acampora
Re: haunted PTT
Well, they are rated for 30 amp and the switch inside is spring loaded--notice I mentioned vibration? I didn't say a failed relay, I said defective. There is a difference.
