PrinceValium
Thread starter- Joined
- Jun 2, 2010
- 421
Re: Have about had it with this motor!
Ok thanks...I was planning on getting another 3 blade prop and possibly back to a 17 pitch depending on the rpm at WOT with my 4 blade.
No you shouldn't have to do it again as long as it was the right prop set-up to begin with. The only thing you might run into is if you put a higher pitch prop on the motor and it slows down your idle-in-gear too much. As long as you are at the correct RPM at WOT you are just fine.
