Get a gapping spark tester and check for good spark on each plug, you should get a hot blue spark, at least a 1/4 inch long from every wire. Leave the other wires on while you check spark, but be prepared for the engine to start. Then do the compression test, you should have 100+ psi and they should all fall within a 10% range. Next spray a little mixed fuel in the throttle body, if it starts look to the fuel pump or a plugged carb.
Compression+ fuel+ spark will = a running engine.
