Have Spark. Have Compression. Have Fuel. No run!
TinPig
and firing order is correct.......
1987 Bayliner with OMC GM 350.
Any Help.
YeboGogo
Re: Have Spark. Have Compression. Have Fuel. No run!
Maybe starter spray to verify that you do have correct amount of fuel?
Blk-n-Blu
Master Chief Petty Officer
Safety lanyard connected?
Howard Sterndrive
timing (distributor) or ESA activated affecting timing
water in cylinders
bad gas
exhaust shutter plugging exhaust
180shabah
NEVER use ether, bad things happen.
OP - if you have fuel, compression and spark it runs so double check everything.
do you have spark on ALL cylinders?
do you have the distributor 180* off?
Is the gas fresh? will it burn?
