Asaracing21
- Joined
- Sep 6, 2013
- 34
Having trouble mounting my Mercury engine Long shaft to what I believe is a short shaft transom.
My transom measures 16 inches along the edge which a true reading would be i believe 15 inches. I could not pass up on this engine its a 1996 9.9 ML Pro series tracker. There is a fin above the ventilation plate itself is this where my motor should be measured from the hull? No manual was with this engine and I would appreciate advice on how this motor should be correctly mounted.
This is my first boat....
