Having trouble pumping out milky oil
buoyboy13
I bought a drill pump to change my oil. I know there is water in the oil, so it is thick and milky. No matter what I do I can't get the pump to work well enough to get the oil/water out of the pan! I tried every way of priming the tubes and everything. I even tried unbolting the dipstick from the pan but of course I can't get it cracked loose. Any other ideas? Oh...this is a 3.8L I/O. THanks
Scaaty
Re: Having trouble pumping out milky oil
Theres always the ancient old way of pulling the drain plug..
buoyboy13
i am pretty sure there is no drain plug. The only fitting in the bottom of the pan is the oil dipstick elbow, which for some reason, is about to rip out of the pan when i torque on it to unscrew the dipstick.
Can i use some diesel fuel to help thin it out?
tommays
The drill pumps dont suck to good :)
aid-auto_1922_36172632
i have had very good luck with these at most any auto store pumps out 5 quarts in a few minutes
Tommays
Coors
I tried a drill pump-no go. A cheap attwood from wallmart worked great (hand pump).
Don S
Why don't you run it and warm it up. Then the oil will come out.
If the oil level is too high, it doesn't matter anyway cause the block is cracked.
HT32BSX115
There's an easier way. Just drain out the oil after you pull the engine. That way you can clean up and paint the bilge for the rebuilt/reman engine......(In reality....I think most wrecking yards will take engines with oil in them anyway .... )
Cheers,
Rick
Coors
You guys are brutal to some one with a cracked block:love:
Gary H NC
I have a Balkamp drill pump from Napa,It sucks so hard it about collapses the hose,but the oil is out in about 2 minutes..
Kind of rough on the poor guy..8)
Don S
Come on guys, why sugar coat it.
If the oil is so thick and milky with water that it won't come out of the engine,then there is a serious amount of water in it. It didn't get there thru the cylinders from a bad manuifold, that would be a couple of tablespoons full. The only way to get that much water is to have a cracked block from freezing, or the engine was under water cause the boat sank. Since I think he would have mentioned his boat sank, what are the other possibilities?
Now if the oil level is ok, he can run it and warm it up and drain the oil with a pump. If it was put away in the fall with milky oil............................. It's probably dead anyway.
Gary H NC
Good point Don,I keep forgeting this is cracked block season..
I wonder if he even tried to start it..
I/O WALDO
I have removed the oil filter and the s.plugs and put a container under the filter housing and just cranked it out before.
DHPMARINE
I must have missed a post.His block is cracked.? I didn't see that that part?Sorry boyboy13.I just thought you had milky oil in your engine you were trying to pump out .
DHP
Don S
Nobody knows DHP!!!
He hasn't posted back with any details. But the ONLY time I have seen oil get so thick and milky has been with a LOT of water. If you read my first reply to him you will see where the cracked block suggestion started.
DHPMARINE
Don,Maybe it's a New England thing,but I see many boats that the owners don't pull the bilge drain when trailering.Then comes the rain,and the water enters thru the crank seals.(yes,that much water in the bilge).It's also great for starter sales!
DHP
Don S
Trust me, it's not just a New England thing ;)
Ayuh............... Worldwide I'd say.................d:)
f_inscreenname
I will second or... forth....that.
My plug goes in before I leave for the ramp (it clips to the keys that unlock the trailer) and is the first thing I pull when I hit the parking lot (its on a big hill and its the only chance what little is in there will come out). The only reason I could see leaving the plug in when not in the water is if you needed to fill the boat up for weight. There was a big debate here a few years ago over that when a hurricane was going to hit a members house. We had one here with in months of his and I decided to block the trailer up with jack stands. I would rather take the risk of something happening from wind then filling the boat up with water.
