johnp34
- Joined
- Jul 11, 2007
- 30
My father-in-law wants to replace the impeller on his 1968 6-hp Evinrude outboard. After removing the lower unit bolts and disconnecting the shift rod linkage the lower unit isn’t dropping. It sounds solid when pulling the lower unit down as if there is something preventing it from dropping. We are 95% sure there is nothing else mechanically preventing it from dropping other than corrosion. If it is corrosion what is the best way to drop the lower unit? Slide hammer? Prying?
johnp34
johnp34
