Re: Head Gasket Check
Well, I did get to pull the head off and inspect...
definate sign of water on top 2 cyclinders. Brown creamy sludge with the occasional clear water droplet...
No signs of cracks or erosions... Only sign of what could have allowed a breach of water is the head gasket itself... Although no cracks or tears, there was a lot of dried gunk on it. I did replace this head gasket a couple of years ago, and when I did, I used a gasket sealer, but probably shouldn't have... could this be what allowed the water to come through?
Attached is a picture of the head gasket...
Any comments on the picture? Also, when putting the new gasket on, I assume I should not use the gasket sealant, correct? What other things should I keep in mind? Anything I should do while the head is off?
