head gasket for mercruiser 165hp
lovetheyz
i have a early 80's mercruiser 165 hp. serial number is A408676. I am wanting to know if i can get the head gasket, exhaust manifold gasket and intake manifold gasket from a napa or autozone. Anyone have a part number??
thanks
do you have the 3.7 liter 4-cylinder or the inline 6?
Napa will carry marine gaskets
betayv
napa, carquest sell sierra get the sierra part number from the sierra online catalog and they should be able to order it.
stonyloam
6 cyl yes, 4 cyl exhaust and intake yes, head gasket no, go with OEM.
Bt Doctur
head gasket should be for the 250 cu in 6 cylinder GM motor. intake/exaust manifold can use the one piece header gasket
Rick Stephens
You can get it from iBoats and they have a special 2 day delivery for $2 more. That probably satisfies the time constraints better than any where else.
Rick
lovetheyz
so i ordered the head gasket from here and have it coming next day. now for the intake and exhaust manifold gaskets. Anyone have a part number i can use at napa or auto zone or something along those lines??
thanks
thanks
Ayuh,.... The very same part numbers ya found for those parts, here at iboats,....
Napa, 'n iboats carry the Same line of parts,....
Fishermark
Doc - he has the 4 cylinder - not the straight six. So that FelPro number is incorrect as well.
Bt Doctur
how did I miss that?????????? Fel-Pro FEL-1419 Ford 460 cu.in. motor, also the valve cover gasket, pushrods, rockers.
intake manifold is marine specific to that motor
lovetheyz
so any header gasket for a 250 cu in 6 cylinder gm motor will work for both sides?
thanks
Bt Doctur
no, the 470/488 motor is mercs bastard child. nothing on it matches to a GM inline 6 cylinder
thanks
Nope,... Ya can't used 6 cylinder gaskets on a 4 cylinder motor,....
The 470 has Never been an automotive motor, Ever,....
