head gasket for mercruiser 165hp
stonyloam
how did I miss that?????????? Fel-Pro FEL-1419 Ford 460 cu.in. motor, also the valve cover gasket, pushrods, rockers.
intake manifold is marine specific to that motor
Sorry Dr. but that is an auto head gasket, prone to failure on a 470, go with OEM Mercruiser, it has extra sealing surfaces added to help mitigate the problems with the iron head on the Al block. Yeah I know 470 world! :rolleyes: The other gaskets, aftermarket (iboats) is fine.
achris
More fish than mountain goat
OEM Numbers
Head gasket: 27-13709T
Intake gskt: 27-70905
Exhaust gskt: 27-68715
You can use those number in the iboats search and find the a/m gaskets, as I did to find these links for you....
iboat links to the required gaskets
Head gasket
Intake gasket
Exhaust gasket
Chris......
(I thought giving you the original head gasket link would have inspired you to search further for the other gaskets you needed)...
lovetheyz
ok i think i got it. i got a oem headgasket from iboats. i got the exhaust manifold gasket from napa and the intake manifold gasket from a local boating store. I also received new head bolts yesterday as well. going to be putting back together this evening.
thanks for all the help.
