heryrg2711
Thread starter- Joined
- Jul 22, 2011
- 84
Hey guys. So a week ago i found water in oil. Took apart the head and found a head gasket with several cracks and some holes. Seems to be original, '76.
I took the head off cleaned it, took out some rust from the water channels, cleaned where the thermostat is with fire jelly, to remove some of the rust. Also cleaned the circulation pump. Getting ready to put everything back together.
My questions are:
Can i reuse the headbolts? They seem ok.
What grease/oil should i use on the bolts when putting them back in?
Should i use any silicone/sealant/grease on the gasket? Or just gasket onto block and then head onto that.
Also, i'm having trouble finding the thermostat for this engine, auto store one doesn't fit. I'm thinking of running it without the thermostat. I found a right size oring and a gasket that fits almost perfectly, to create that seal the thermo forms. What do you guys think?
My questions are:
