Re: Head Gasket Replacement
Thanks guys, wasn't sure. I think last time I did it, was when it was still hot. Last time I took it on the water and opened it up WOT, the gasket blew between the 2 cylinders. This time I really took my time and re-dressed the head with a sheet of sandpaper and a granite surface plate that we have at work. Pressure tested at 70-75psi for both cylinders when I got it back together.
It was warped pretty bad. I think that was the big problem as far as getting and keeping it running. I took it out yesterday and opened it up, it seemed to run well at WOT.
Now I need to spend time on the shifter problem, and lower unit seals.
Marv
