Re: HEAD OVERHEATING NEW STAT NEW WATER PUMP
When you replaced the impeller, were anyy of the vanes not accounted for? This is a serious question, becuase when an impeller fragments inside the housing, many times, the pieces are picked-up and lodged in the cooling circuit.<br />Remove the thermostat, and backflush the housing with as much pressure as your hose can give you. Do the same with the pickup tube. If these steps dont work, you may have to remove the exaust manifold and head, and clean out all the ports.<br />Did you get the exact same replacement for the thermostat?Thikning also could be a temp difference?
