Head Removed ::Mercruiser Inline 6 Cylinder
MercMonster
I removed the inline 6 cylinder head from the block just minutes ago and found no visible cracks on the head and there was just a hint of moisture around the edges of the piston in the back cylinder. No visible cracks in or around the cylinders either or the block that I can see. It looks like there was a location in the head gasket itself where water may have penetrated into the oil. No cracks or tears in the gasket itself though. Is it common for water to leak between the gasket and head and flow into the oil. I have pictures that the missus is downloading right now that I may post shortly if anyone cares for a look. I'd like to go match up and get the gaskets (head & exhaust) today. The exhaust gasket was leaking water slightly in the rear to the underside of the exhaust manifold. What else should I look for in the interim while the head is removed? The water jackets are pretty built up with rust. Is there a way to flush out some of that rust? Should that be done once the head is reassembled?
MercMonster
Re: Head Removed ::Mercruiser Inline 6 Cylinder
Here's the rear cylinder:
I'll post some more here....
MercMonster
I don't know if this is anything or not:
Ha, was just looking at this pic on the computer and saw what looked like a crack. Went out to inspect it on the boat and sure enough, cracked manifold. Can that be repaired (welded, jb weld?) or should I look for another one?
MercMonster
Here are the cylinders from front to back:
Waiting on how I should proceed....;)
Windykid
Pull the gasket off and clean head. Inspect for cracks. Have magnifuxed if uncertain. Clean block. Inspect. reasemble.
ziggy
look for another one. + do the riser too.
got mine at perfprotech.com
when i R&Red my manifold. i took the old one and filled up the waterjacket with water. next morning all the water was in the exhust runner, none in the waterjacket......
jimfj
Hello,
I have the same engine and a little water in #2 cylinder. Marine mech said it was probably headgasket. The only clue was a low end miss and and a difference in color on the plug. The only way I knew any of this was compression test.
Did you do a compression test before removing head?
What was the motivation for taking the head off?
Thank you for the pictures this newby really apreciates them!
Jim
MercMonster
The previous owner stated that the "head gasket was blown". When the engine was started briefly, I checked the oil and it had the "milkshake" look. I wanted to get this thing ready for the water and see what all was wrong anyhow.
Only I keep finding more and more wrong:eek: After I found the original hairline crack, noted in box 2 below (although hard to see in this picture), I looked inside the channels after hearing of ziggy's problem. Inside the channel in box 1 it looks like it exploded outwards from buildup of heat.
So that manifold is pretty much scrap from my point of view. And as I was looking over the manifold, which was still attached to the riser and rubber connector attached to it, the rubber hose snapped in half and you could tell that the inside of that rubber connector had dry-rotted. So now I'm adding that connector to my list of parts. (what is the name of that connector, BTW) HAHA:) This is getting so horrible I can do nothing but laugh and keep treading forward. Thanks for pointing that out ziggy!;)
MercMonster
After a few more purchases, my budget is going to be blown for this month. What can I coat the cylinder walls and exposed metal surfaces to keep rust from forming?
MercMonster
Looks like I can answer my own question now...
I've found its the bellows assembly. Anyone have a source for this part?
Coors
Coat the walls with grease.
MercMonster
I'll do that!:)
Has anyone used Stem to Stern? I found availability for the bellow assembly on their site @ $55.85 Does that sound reasonable?
