Re: Head stuck on 1970 18hp evinrude HELP
You will want to lap the head to make sure it's flat before you put it all back together. They tend to warp in the area between the cylinders. Lay a straightedge over all the surfaces of the head and block and shine a light behind it to see any high and low spots. You can lap the head yourself with a piece of glass and some sandpaper. Do a search on this forum for "lap head glass flat" and you'll find out more details. It's cheap, easy and may solve your dissimilar compression problem.
Here's a link to one post for lapping info.
http://forums.iboats.com/showthread.php?t=534366&highlight=glass+lap+head+flat[/QUOTE]
Thanks I will look into that. I was going to get my brother in law with a milling machine to mill just enough to make flat if needed. THE HEAD IS OFF. I had to do ALL the bad things to get it off. The three bolts that do not expose out the case were rusted and pitted to the head. Had to drill out the best I could (drill drifting into the head area). Soaked with penetrant and LOTS of heat. Used a thin blade to cut loose the gasket, and YES pry the head off. Hammering did not do it. TOOK THREE DAYS. No apparant damage to gasket surfaces thank god. So
1. remove the three head bolts
2. remove the four exhaust cover bolts (also broke)
3. mill the head and case surface (careful not to change compression)
4. hone the cylinders.
5. order parts.
Thanks for everyones input. Look for new posts of progress
