IRBFishin
Thread starter- Joined
- Jul 19, 2009
- 30
I'm not sure if this is a coincidence, but the last time we trailered the boat I took someone's advice and put the throttle into gear to keep the prop from spinning. I had never done this before. When I went start the boat in the water the typical one beep alarm check went off and stayed off but the check engine light (the bottom of the four lights) stayed on. The motor ran just fine for the trip, peed a good stream and had full power at all RPMs. It still hasn't gone off and I'm waiting to get into a shop (timing is terrible with the time of year).
I know there's lots of threads on this topic, but was curious if anyone thinks the trailering with the throttle in gear is just a coincidence. Also, is it really that unsafe to take it out and use it until I can get it plugged into a DDT? Any thoughts for DIY efforts to fix it, such as checking the throttle cable or something? Again, it runs great and the alarm does not sound after the initial beep, but the light stays on constantly. It's a 1998 Mercury Optimax 150 DFI on an 18' Fisher (Nitro) fish and ski.
Thanks for any advice.
D
D
