Heat gun should be here tomorrow...
airdvr1227
...and then it's off with all the tacky decals Carver thought looked good in 1989.
mr 88
I would buy a eraser wheel from a auto parts store to supplement the gun. Hooks up to your drill,[ corded/electric] and works great after the top coat of the decals are off. You don't have to press to hard,let the rubber compound on the wheel do the work..
airdvr1227
I have one of those as well but to get the wide vinyl off it gets too hot and leaves a residue that's almost part of the gelcoat. And, the stripe at the waterline is all beat up. I'd be there for a week with that wheel.
mr 88
I said to use the wheel after you have gotten off as much vinyl as you can with the heat gun. Usually there is a residue left that the heat gun misses here and there.
JimS123
The wife's hair dryer, an old bath towel and a $2.99 quart of acetone from the hardware store. Only a little elbow grease needed. BTDT No need to buy expensive hardware. The worst part is then finding dark shiny gelcoat that doesn't match what was outside the decals.
NYBo
There was not too much that looked good in any of the 80's.....
What, you don't like this look???
airdvr1227
While the heat gun was good for getting into the corners the eraser wheel was definitely the quickest. A little acetone to get the residue and it looked good. Spent yesterday on the end of a buffer followed by two coats of wax. Still more to do but it's getting there.
2016-04-26_09-12-42
Sorry. Only pic and none of the before and after. I forgot the before pic.:culpability:
