HEAT in fuel to clean water out?
chbailey
Will HEAT, in mixed 50:1 fuel, clean out water? How much should be used? Or should I just write that fuel off and start over?
rickdb1boat
Re: HEAT in fuel to clean water out?
Best to discard the fuel and start with fresh. 2-strokes hate water in the fuel...
offshore100
How much fuel are we talking about? For six gallon tanks I pour it into clean, white 5 gallon buckets, water settles to the bottom, then I pour fuel back into the tanks through one of those conical paint filters. Works a treat.
Pugs2007
I highly recommend the OMC 2+4 Fuel Conditioner. It should take care of the water problem plus it's a fuel stabilizer, it conditions and lubricates seals and other rubber parts in the fuel system, and it will prevent and dissolve varnish in the tank and the rest of the fuel system with regular use. A must for storage.
chbailey
I drained fuel system and switched tanks. Motor is running again. I'll use OMC 2+4 Fuel Conditioner for sure. :)
