brekonripper
Thread starter- Joined
- Mar 13, 2008
- 7
I currently run two different props but both are 14.5 x 19p.aluminum. The main one we use has tons of bow lift, it works great for wakeboarding when its just our family of four, feels like it digs a giant hole in the water and puts out a decent wake. But I am constantly making trim and throttle adjustments to keep it on plane at lower speeds. Also feels like it rides low in the water and the boat seems to pound in chop.
The second 19p. I have is totally different, it has tons of stern lift. Again under light load this prop works great I feel like it makes the boat ride better in chop and I dont have to keep adjusting the throttle to keep it on plane at lower speeds.
I really like how the #2 prop feels, the problem is under heavy loads it really struggles to plane out. The #1 prop has no problem getting going under heavy loads but I feel like the boat rides rougher through chop.
So I would like to find a prop that acts like #2 but can perform that way under heavy load or at altitude. Hopefully through my rambling some one can make sense of what I'm feeling and point me in the right direction.
1997 Wellcraft eclipse 2000 ss. 5.7 VP.sx 1.60, 220 hp.
mostly used for tubing, wakeboarding and cruising.
Length 20.5, semi "V", clean bottom
8' beam
3300 lbs. dry
Normal load 700 lbs.
Prop #1 48mph @4800 Prop #2 48/9mph @4800
Heavy load 1600lbs
Sorry no wot #s but prop #1 can cruise 30mph @3500
8' beam
3300 lbs. dry
Heavy load 1600lbs
