Ki Ki
Thread starter- Joined
- Jul 12, 2010
- 292
Re: HEAVY oxidation, Fiberglass Restorer failed. What next?
Okay, this is very helpful. So after I wetsand use a good wax and that'll restore the shine a bit?
You can try the Meguiar's oxidation remover by itself on a small area. It has some abrasive in it so it can scrub off a bit of oxidation. If that doesn't bring the shine up how you would like it then go ahead with the wet sanding. The wet sanding will remove the oxidation and level the surface, but will leave a dull finish. Follow up with a polish to bring out the shine. The Meguiar's oxidation remover will work for that.
Older boats are probably better able to take the wet sanding because the gel coat is thicker on the older boats. Even on the newer boats the gel coat is probably 10 times thicker than a typical car paint job. If you are just sanding enough to get rid of the oxidation then you will be fine.
