RacinRob
Thread starter- Joined
- Aug 29, 2013
- 31
Hi all,
Glad to have found you. I have found a ton of info will cruising through the site.
I just opened my own can of worms on my Brendella. Was vacuuming the carpet and noticed a soft spot on the drive shaft cover. Pulled back carpet and thought, no problem, I can fix that. Well after finding all the other bad spots I cut most of the floor out. Which of course led to more discovery. No I'm starting where Hilton did on his Brendella. Engine coming out today or tomorrow depending on how I pull it. My goal is 30 days. I'm not working much so I have the time. As long as that time does not cut into my kayak fishing time. I'm am happy to have found a good thread on the repair. I am very good at rebuilding anything from cars to houses so, one more thing here to add to the list of rebuilds. Let the fun begin.
I do have a question now. I have cut most of the front part of the stringer out. In the front where the front floor under the deck is is in good shape still. The dilemma I have is the stringer runs another foot or so under that floor. The front section of the stringer seems to be dry and good. Can I do a butt joint right there instead of pulling up the front floor. Or do I need to run the new stringer up that extra foot to the front. Before I cut it out I thought I would ask. I thought I would also seal that off with glass as to not expose the new wood to that old piece just in case it could contaminate the new. The little bit of deck up there just on that little section is coming off. A couple pics attached here.
Last question. When I cut the floor out I left a ring around the edge. I am going to trim a little more than I this picture. Can I, as seen in this picture, put a piece of ply under the old floor screwed or glassed in, and then screw/glass the new piece on top of the under ply? I don't want to put the new wood on top of the old glass edge because it would raise the floor 3/4" and be on an angle if I make the stringers the same height as original. If I raise the stringer to level then my seats are all going to need to be modified.
Thanks for all the help and head start I gained from Hiltons thread, Rob
