hello, merc question
badfish888
Hello, new to the forum. i have a 2001 angler eagle c/c with a 125 saltwater. when i aquired the boat. the audible alarm system did not work. I dont even get a the test alarm when i turn the key. Were should i start with this
thanks in advance
badfish888
Re: hello, merc question
soooo, ok does anyone know if the alarms are tied into the main wiring harness?
Silvertip
Honorary Supreme Mariner
At one point or another -- yes! The module needs power in order to function. The temp sender on the engine is a snap switch that closes when the engine overheats. That puts a ground on the module and the horn sounds. So here are two tests:
1) Locate the temp sender on the engine. It has a tan wire going into it on the water cover.
2) Follow that wire to a bullet connector.
3) Disconnect the bullet connector.
4) Turn the key to RUN
5) Ground the tan wire (not the sender end -- the other end).
6) Since the horn doesn't sound during the key on self-test, it likely won't sound with the wire grounded but check anyway.
7) Check the input to the module for +12 volts. If it's present, replace the module.
badfish888
is there away to check and see if the horn is still good? like manually make it sound?
badfish888
well, between this and googleing, i found that my engine, doest not have a (check) beep when the key is turned, But i did as ^^ silvertip told me and manually grounded bolth sensors and got a continuous sounding horn with bolth, thanks for all the help
