tperk100
Thread starter- Joined
- Oct 10, 2009
- 84
My '97 boat and its scuppers sit so low in the water that I have to plug my main storage compartment or else it will take on about 3 inches of water which does not drain out until on plane or trailer. The real problem is when it rains or I wash the boat, the compartment fills with water and does not drain unless I remove the plug........but then I got to remember to put it back in..... a PITA. I would like to fix this.
My scuppers are located on the bottom of the transom, under the water line (I suppose this is why the compartment floods). They are 1.5" ID. Pic attached. I have looked at numerous one way scupper valves, but cannot find anything that I think would work for me. It seems to me that a device such as these would have to mount almost flush with the bottom of the transom so that it will not hang down below the bottom of the hull.
I have tried unsuccessfully to simply improve the seal around the compartment hatch. Pic attached. Just can’t get it water tight. This might be the easiest fix if I could just figure out how to do it.
Another solution might be to install some sort of one way valve into or onto the compartment’s interior drain hole. Pic attached. This is 1.5” ID.
Any help will be appreciated.
