Gary H NC
Thread starter- Joined
- Dec 1, 2005
- 8,972
After spending a ton on parts to rebuild the lower gear case I got it back together tonight.
I replaced the brass bushing,gasket and rubber o-ring on the shift rod and it leaks like crazy!
I even used the tool made for this job to drive the bushing out and install the new one.
Used aviation gasket sealer on the gasket inserted first then the new O-ring and seated the brass bushing....
Going by the original OMC factory manual..
All surfaces were clean and it should not leak.
Any ideas to the guys that work on these old?
The O-ring has some resistance on the shift rod but I was not happy that it wasn't a tighter fit..
Ordered the original OMC parts.
