Help 1975 evenrude
snakpak13
It will only run with the choke on ??? New points - plugs - wires: Once i turn choke off it gains rpm then dies???
Daviet
Re: Help 1975 evenrude
Sounds like it's time to check fuel lines and clean carb.
snakpak13
removed carb checked very clean fresh rebuild before i bought it . fuel lines are sound .
i brought home ran 3 days later problem started
Daviet
If you have to use the choke to keep it running, it sounds like a fuel problem.
What is your model#?
