Iowaboatguy
Thread starter- Joined
- Mar 14, 2018
- 11
Motor is a 1979 115 hp Johnson. The problem I'm having is that when I have it on the muffs it idles very strong, shifts into lowest gear perfect and then throttles all the way up perfect as well. Runs like a champ on muffs.
When I put it in the water, it doesn't idle as high, almost sounds like it wants to die. If it happens to stay in idle, once I shift into drive, it dies. The only way I can get it to run is to have the fast idle lever all the way up then slowly ease it down 3/4 of the way and then slam it into full throttle all the way and put the fast idle lever down and drive that way. If I slow down to lowest drive speed it neutral, it eventually dies.
Here's the catch, I've done alot to trouble shoot:
Cleaned carburetor, repalace all 4 spark plugs, replaced the gas tank, replaced the gas line twice, replaced battery, replaced all the hoses from the intake/fuel pump/fuel filter, checked the fuel pump and filter, manually increased the idle screw to maximum.
I don't know what the problem is to save my life. It runs fine if I slam it in full throttle, but anything lower and it dies.
Any ideas?
Any ideas?
