Need help with Dx. Have no reason to complain with this motor. I have had it since new and this is the first problem I have had.
first noticed problem when it appeared i dropped power with no hesitation or spitting and sputtering. though it was running on 2 or 3 cylinders. brought home and tested each plug. I had no fire on cyl 1.. and the plug was oily..changed colis and power packs around from side to side one at a time to isolate the problem. however during the changing of parts miraculously all had started firing again. I then put all parts back in their orig spot and tried again. still power to all cylinders. started the engine and it ran fine, however when i tried to shut down the engine by the ignition switch only partial cylinders shut down and the engine continue to run with the switch off. it appears the engine is running on 2 cylinders with the ignition off. when i turn the ignition back on all 4 cylinders power on again..does this sound like a power pack kill switch not shuting down? can i rule out bad coils? does this sound like another electrical problem? I have only basic knowledge with an ohms meter is. how can i isolate the problem before i start buying parts?
