HELP! 1985 Johnson 70hp, no spark..
Bill Foote
OK, Let me first explain the situation. 1985 Johnson 70hp, ran well all summer and then in Oct/Nov. it started acting up taking a long time to start. So, upon finding that the plugs weren't firing I began troubleshooting. My suspicions led me to the power pack and stator. So, I purchased these 2 items (CDI brand), installed them and bang! back in business.
Since then the boat has been used about 3-4 times flawlessly. Until, last week I tried to fire it up and nothing. No spark. So, back to troubleshooting, here is what I have observed.
1. Stator output: 140V ac
2. Timer base output: .2-.8V ac Also, no continuity between any of the 4 wires on the timer base plug. Shouldn't their be some continuity between the center white wire and the three other wires?
3. Ignition coils: when removed from engine and tested independently they all had consistent resistance, .248-.251ohm's between the posts and ground tab. Also, I noticed that some of the coils have the potting goop bubbling and oozing out of the back of them. It has been my experience in the past that this usually indicates a faulty electrical part.
So, my questions are; Should I have some amount of continuity between any of the timer base wires, and what would cause the coils to ooze as I have described. Though I feel it would be unlikely for all three coils to fail at the exact same time... If the timer base and coils are faulty, is there a chance that they have destroyed my brand new power pack?
Thanks in advance
SparkieBoat
Re: HELP! 1985 Johnson 70hp, no spark..
stator and power pack voltage must be measured with a DVA adapter that will work with most multi meters. google it $35 ... coils are cheap get new ones I recommend staying with the CDI they also have coils that come with a new plug wire..nice little combo. also use the recommended Champion plugs and get a new set before ordering the coils
Bill Foote
Thanks for the link thasasdaddy,
I have just replaced the battery in my multimeter and followed the steps outlined in your link. It is begining to look like the timer base is the culprit. Resistance on the timer base wires while disconnected from the power pack is as follows: white/green=11.5 white/purple=20 white/blue=infinite discontinuity
The link specifies these numbers should be 38-42ohms
That being said, is there any possibility that a faulty timer base could harm a new power pack?
