Ok here is what is wrong and what I have done so far. The problem is it runs like a cylider or 2 is coming in and out. Like intermittent spark. I will idle and push my boat about 20 or so but it surges anything beyond that.The more throttle you try to give it the worse it runs. I have checked compression, good. I put on a new cdi, rebuilt both carbs, and put 2 new coils on it. I also switched the new coils around to see if it would make a difference, but it still runs the same. I also changed the spark plugs just in case 1 of them was bad. No change. Help need suggestions.
