askmelater
- Joined
- Sep 14, 2010
- 23
Re: HELP - 2000 Evinrude Ficht Oi/Bearing
All Pistons were 125 and I was happy to hear that. That's the first thing I did.
I put some Lube in all the spark plug holes and the motor turns over easier manually. (Got nailed on the chest with lube
The SCRAPING sound appears to be coming from the gear case - not the pistons. The other motor doesn't make any sound when turning manually.
The KNOCKING sound sure sounds like its coming from the oil injector side or specifically crankcase. I thought that - the mechanic who hooked it up to a computer thought that. He thought it was one of the main Crank Shaft Bearings.
I'm wondering if there is any chance the lower gear is knocking and the noise is traveling all the way up the motor to flywheel and crankshaft housing?
I was told to check lower gear first because that can happen and I did. The motor with the problem had a slight milky green color and a few small metal pieces on the filler screw. The other motors oil looked brand new and no clippings.
The motor with a problem makes a slight knocking or clicking sound when you spin the prop by hand and appears to might have a slight bend in the shaft. Minor stuff though.
The SCRAPING Sound coming from the mid to lower section sounds VERY ODD. Sounded like a tight un-lubricated piston rubbing but perhaps not.
Have you checked compression? Cylinder scoring will always cause compression to be down. You're probably hearing bearing noise, with quite a few possible choices (wrist pin, rod, main bearings) or damage to one or more of the surfaces the bearing ride on. Piston slap is another possibility.
