Jstumbough
Thread starter- Joined
- Aug 1, 2012
- 24
I just bought this boat, i have yet to get it in the water. As soon as I got it I went through it, dumped the old gas and put in fresh non ethanol 93 octane as well as fresh spark plugs. It starts up like a champ and will idle fine. But it seems like its missing and every few seconds it bogs down and shoots out a big puff of exhaust smoke, violently shakes the motor, then recovers.
I just did a compression check (used two different gauges) and no matter what, warm or cold, wet or dry, it's reading 35 psi on all 3 cylinders.
So here are some Questions:
Is there anyway my readings could be flawed?
Should a motor be able to run with such little compression, especially with high octane fuel?
Are there any other problems that could produce my results besides worn rings?
This is my first Motorized boat, so any insight would be greatly appreciated. I consider myself to be capable working on cars and such but two stroke marine engines are not within my comfort zone. However I'm not too timid about turning wrenches on something new so I'd like to fix this myself.
Thanks a lot for any help.
