jts76240_2005
Thread starter- Joined
- Aug 5, 2005
- 7
I want to start off by saying great site guys.<br /><br />Well here goes I have recently aquired a 75 Johnson 70hp that doesn't run correct. On its maden voyage with me I gave it plenty of chance to warm up and took it for a fast run. I applied throtle and everything ran smooth up to about mid throttle. Then the poor thing fell on its face and wont rev any further. So I suspected a possible fuel blockage. I have no clue how long it may have set. Upon inspection the carbs look great and are very clean. It is my guess they have been rebuilt recently (someone scratched numbers in them 1,2,3 lol). Also what confused me was there is no adjustment for the mixture either it seems to be all preset by the jets. So I checked the fuel pump and it was spotless as well. Then I went back to basics and changed the plugs. To me they seemed a bit wet but I am not too knowledgable with 2strokes. I took it for a run again and same thing. Then all of a sudden it kicked in and went full throttle. Ran great for about a minute then fell again and has been the same way since. Every now and then it will bump a little and rev up but falls right back off. I read on here that if it was a fuel restiction that if you pull the choke it will try and go faster. So I tried this as well. This didn't work and it acted as though it wanted to die as soon as i pulled it. To me it also consumes an excessive amount of fuel. I did read as well that the regulator can cause the problem I am seeing but it seems to charge great too. It will run all day long like this and never miss a lick. Any suggestions on this would be so great.
