help a noobie
boslaw
Forgive me if this is a stupid question but I've never towed before.
I have a 2002 sequoia with towing package, and I'm about to buy a 1997 20' grady with 1997 venture double axle trailer.
What do I need to tow this? Is it just a matter of getting a ball & ball receiver or do I need more?
I'm having a surveyor take a look at the boat next Wed, but he doesn't survey over land vehicles like my trailer. Boat is at a boat yard.
Thanks
tashasdaddy
Re: help a noobie
what is the weight of the boat and trailer, what is the tow capacity of the vehicle. you need draw bar, correct size ball, wiring harness, safety chains. tie down strap for strern of boat.
boslaw
Re: help a noobie
Thanks. I believe the trailer comes with stern tie down straps + chains. The sequoia comes with a wiring harness as part of the tow package that I have. I also verified that the sequoia has sufficient tow capacity for this boat + trailer. Only thing that seems to be missing is the ball but I wanted to make sure.
BamaAlum97
Re: help a noobie
Match up the wiring on your tow vehicle to the wiring on the trailer....you may need an adapter. My tow vehicle has a 7-way round connector on it. I have one trailer with a 4-flat and second trailer with a 5-flat. I found a single adapter that will convert the 7-way round to either 4 or 5 flat. They have them at iboats, or try your local marine store.
tashasdaddy
Re: help a noobie
toyota dealer has them for $11.00. Cheapest place for drawbar and ball i found was walmart. but you need to get the correct drawbar, either straight, drop or rise, so that the trailer is level when connected.
boslaw
Re: help a noobie
thanks - this is perfect. I was freaking out that I was going to have to buy a bunch of stuff, but I was hoping it wasn't more than the ball, adapter, and maybe electrical adapter.
DRIFTER_016
Re: help a noobie
You might need a brake controller if the trailer has electric brakes.
tashasdaddy
Re: help a noobie
remember when backing, put you hand at the bottom of the wheel, then move your hand the way you want the trailer to go.
INJUN
Re: help a noobie
After you get it hooked up correctly, find an empty parking lot and practice manuvering, especially in reverse. Put some markers (or something you can visualize) out to indicate where you want to back up to.
You don't want to practice at the ramp.:cool:
