Re: help- big crack in outdrive... how much will this cost me
A 3.0L engine is not all that hard to remove. I would pull the engine and transom to do the job. I would want to look closely at the transom and gimbal after an impact that caused that.
Here's the
GEN II gimbal ring from Ebasic Power.
[FONT=Arial, Helvetica, Sans-serif]
Part Number: MER865328A01
Price: $499.00
[/FONT]
Thanks all.
So is this the some total of all the parts I would need to buy? I've read that it's a good time to replace the flextube (exhaust) while I have things apart. I hate to dig into it and find that I'm missing a required part - that's going to take another week to get here.
I'm leaving for a trip on July 7th- so I don't really have a ton of non-weekend/holiday time.
btw- I agree, after looking at the 3.0, it's pretty compact and appears to not be a big deal to remove. Frankly, my biggest problem with the motor is getting it out of the way. I don't have a hoist setup at present. I expect that it needs to be totally out to accees the top section?
For those that have done it - J&R method and motor removal - how much time should I set aside. My guess is that the motor removal method takes significantly longer - clearly the best approach.
