svillebrian
Thread starter- Joined
- Jun 29, 2008
- 41
I have a 2001 90hp 60 degree Johnson. I am still running the VRO fuel pump on the motor (which was replaced last year). I have recently started burning alot of oil in my fuel mixture, roughly about 1 1/2 gallons of oil to 20 gallons of gas. I listened to the oil regulator on the fuel pump and it is clicking about every two seconds at idle. The motor loads up bad at idle, smoking bad, but will run fine at W.O.T.. I am assuming that the fuel pump has gone bad again, but am asking for other opinions or suggestions if there might be another possibility to look at first before I spend another $300 on a fuel pump...
