HELP! Cant figure out which water pump kit!
Fletch_n
Hi guys,
I have a 1992 55HP Commercial Johnson, I ordered a new water pump kit for it Pt no 396933. I got the part number off of the Shop2.evinrude site, but when I pulled the gear box off and took the water pump off I ran into a massive problem...the kit doesn't fit, nor is it close! Bigger housing, impeller and the holes where it slides down the shaft is smaller in the new kit - see pic.
It was an ex Australian Army motor and thats all I know, it takes the larger diameter 13 spline prop if that helps?
Which kit do I need to order? any help would be great.
Cheers
Fletch
ps any one in Australia want a cheap water pump kit? Pt No 396933?
Fletch_n
Re: HELP! Cant figure out which water pump kit!
part number on the old housing is 438545? Does this make it a 1995 year? Army removed tag and everything was Matt black when I got it
hidef
Try this part # for the kit 5000308 KIT AY,WATER PUMP $79.99 and this part number for the 0437059 IMPELLER ASSY. $52.96
OEM Parts
I cross referenced off of your old housing.
Fletch_n
Thanks hidef
Going on that, woul this motor more likely be a 97ish?
Thanks again for your help
Fletch
hidef
Possible I just crossed matched the part number and a bunch of different engines came up. See if you can find the welch plug on the block that should have the serial number and model number.
Fletch_n
Thanks for your help, unfortunately only a part number on the welsh plug, so buggered if I know?
