stratos275xl
Thread starter- Joined
- Mar 24, 2013
- 41
Ok. I posted yesterday but after re reading I realize I wasn't making clear what I need. Ok so I have a 94 stratos275xl with a 95 mercury blackmax 150xl 2.0 with oil injector removed and im mixing 50:1 . from what iv gathered the dry hull weight is 1200# correct me if im wrong but motor is in the 400# vicinity . usually only run around 15gallons of fuel "About all I can afford". and 3 batteries.and light gear load.i weigh 195 my partner that fishes with me around 220 and is with me 99% of the time. it is snowing and cold here so I done just a quick measurement and the motor is approx. 3 1/2 to 4" below the pad I have "hijacker" manual jackplate not sure of offset around 4" I would guess. the prop I have on it is precision turbo ss 14.4x24p. best top speed run was gps speed of 51 to 52 at 6k. in lows 40s at 5500 now In not 100% sure if tach is correct because of the motor swap with all original electronics. Now I have heard of same rigs with same motor/prop pitch doing hi 50s to some breaking 60. .So my question is do you think I could gain anything with a better quality prop and if so what pitch and brand?the prop on it has sum nicks and small bent places but nothing major and no vibration.And its not blowing out trying to come on plane. But iv heard the precision turbos aren't really that great of a hi po prop.the current holeshot isn't something to brag about but I can live with it and may have a little to do with 50:1 mix and a huge No wake zone to have idle thru. seems little better after warms up but not much.So any recommendations on prop would be appreciated and maybe an estimate of what it should do. Also I do not have a WOT speed vs rpm because can pull 6k in drop of hat and have to back off it and that's not trimmed out all way.But like I said not 100% sure on tach.
